KeyShot Testversionen
If you don’t have a license you can select Start a Trial, which will give you access to a trial.
All Trials require that you are online and signed in to KeyShot with your KeyShot Cloud account (the one you use with the Cloud Library).
Die Standard-Testversion ist 14 Tage gültig und erfordert keinen Probecode.
Anmerkung
The standard Trial will give access to the feature set from KeyShot Pro + KeyShot Web but will have limited usage of the options: save, background render and rendering queue. It will also have a watermarked render output.
Probecode aktivieren
For a trial of a different license type please contact [email protected] or your local reseller. You will be provided with a trial code that you need to activate inside KeyShot.
For more information on how to manage your subscription licenses see Subscription.
