KeyShot Trials
If you don’t have a license you can select Get a Trial, which will give you access to a trial.
All Trials require that you are online and logged in to KeyShot with your KeyShot Cloud account (the one you use with the Cloud Library).
The standard Trial is valid for 14 days and does not require a trial code.
The standard Trial will give access to the feature set from KeyShot Pro + KeyShot Web but will have limited usage of the options: save, background render and rendering queue. It will also have a watermarked render output.
Activate trial code
For a trial of a different license type please contact [email protected] or your local reseller. You will be provided with a trial code that you need to activate inside KeyShot.
For more information on how to manage your subscription licenses see Subscription.
