The Geometry nodes will transform the shape of your geometry in a non-destructive manner. This way you can always replace the material and the geometry will return to the original shape.
![](https://manual.keyshot.com/wp-content/uploads/2020/07/BubblyMangoDuck.jpg)
![](https://manual.keyshot.com/wp-content/uploads/2020/07/StyroDuck.jpg)
![](https://manual.keyshot.com/wp-content/uploads/2020/07/FlakeyDuck.jpg)
![](https://manual.keyshot.com/wp-content/uploads/2020/07/DuckMcFuzz.png)
Execute Geometry
Geometry nodes are the only nodes that do not update your material in real time when you edit/set them up.
After any edits to the material you must “execute geometry” before you can see the effect in the Real-Time View. This can be done in a number of ways.
- The
Execute Geometry Node button in the properties panel will only refresh the current material.
- The
Geometry Nodes button in the Material Graph ribbon will refresh all geometry nodes in the scene.
- The hotkey Alt+G will refresh all geometry nodes in the scene.
- In the Real-time View an indicator
in the top right corner will show that the scene contains un-executed geometry nodes. Click it to refresh all geometry nodes.
Tip
If you want to bake your displacement into the geometry, you can export your displaced object and re-import it into your scene.
If you experience problems with opening scenes with e.g. heavy displacement, you can try to open it in recovery mode. This means that the scene will be opened in Performance mode and that no geometry nodes are executed. You can find the option in the Main menu > Help > Open (Recovery mode)…
