This section covers all items found in the Image tab of the Project Window.
Resolution
The Resolution determines the size of the image that is rendered in the Real-time View, and dictates the aspect ratio used in the Render dialog.
Image styles
Image Styles allow you to add non-destructive image adjustments to your scene and see the result instantly. The Image Style adjustments include tone, curve, color and image effect settings that can be applied and seen in the Real-time View or render output window.
