This section will guide you through the steps necessary to view the real-time window through a VR head-mounted display:
- This will only work with the Oculus Rift and OpenVR compatible headsets, such as the HTC Vive, Valve Index, and Windows Mixed Reality headsets.
- These instructions assume that you have the Oculus Rift or an OpenVR headset already installed and ready to go.
Perspective Realtime View
- Open and setup the scene of your choice in KeyShot.
- Go to the Project window’s Camera tab and open the Lens Settings accordion.
- Select Perspective mode.
- Enable the Stereo radio button.
- You can change the stereo settings if you know specifically what you need or you can just leave the default settings the way they are.
- Click on the Head-Mounted Display drop-down and choose which VR device you have. For the Oculus choose Oculus Rift and for an OpenVR headset, choose OpenVR.
- It might take a few seconds for the VR device’s software to load but you can now put your headset on to view your scene.
Panoramic Real-time View
Workflow 1:
- In the top menu, go to Camera → Enable VR.
- Choose between Cube map mode or Spherical mode.
- Choose your desired resolution. Keep in mind that the higher you go the more powerful your machine will need to be. For example, if you are working on a laptop, you should stay at lower resolution.
- Choose which VR device you have. For the Oculus choose Oculus Rift and for an OpenVR headset, choose OpenVR.
- Click Start. (It might take a few seconds for the VR software to start)
Workflow 2:
- Select Panoramic mode.
