If Logging is enabled for the worker/manager, you can access logs via the monitor. The log files keep track of Network Rendering state, information, and errors.
Enable logging
To enable logging, launch the KeyShot Network Configurator on the worker/manager and enable it in the Logging settings. Here you can also select which incidents to log and for how long the logs are stored.
You can also enable the Log Level Mode via the Monitor, to turn on/increase logging to the highest log level (Trace) on both manager and connected workers. Log Level Mode can be enabled under Help > Log Level Mode by anyone with admin credentials and will remain until the manager is restarted or an admin disables the mode.
Access logs
Logs can be accessed via the monitor.
- For all logs: Click the Request all current logs button
- For logs from specific worker: Right-click the worker, you want logs from, and select Request current log file.
